Cub Cadet 1872 hydro problem
/ Cub Cadet 1872 hydro problem #1
v62race
Will a hyrostat out of a 682 work in a 1872? If not what other cub trans will work without modifications? The guy who has the cub said that the hydro quit pulling. What are some things that can be replaced on the trans to try and fix the existing trans. Thanks for any help.
/ Cub Cadet 1872 hydro problem #2
For the existing trans maybe change fluid and filter? I like to get it warm before I drain too.
/ Cub Cadet 1872 hydro problem #3
V62,
Yes the 682-782-1800-2000 series from 85-92 era should all work - Cub used the same hydros in them. If you do a search on line you can find this out.. THe earlier verisons than the 1800 series might have a cast rear end which is preferred. Also if your 1872 doesnt have the hitch plate (hitch is attached to the AL rear end) I strongly suggest the rear hitch plate that connects to the frame rather than the rear transaxle.
As far as getting a hydro working assume this is your 1872, so as suggested, clean Hytran fluid, Cub filter (some 3rd party filters will block flow) so its cheap insurance using a OEM.
The other things are the relief valves on top of the hydro usually they leak first but if stuck can cause issues.
You really dont provide enough info to reallly help your situation.. Please clarify what you are really trying to attain!
