NormL
Platinum Member
- Joined
- May 9, 2011
- Messages
- 662
- Location
- Manitoba, Canada
- Tractor
- Craftsman GT18, Ford 601 / FEL, Oliver 550 / FEL
A generous neighbour of ours dropped off an old but well maintained CC1811 with mower attachment. He told me it had sat for ten years or so but started right up when he put gas in it and checked oil levels. He knew we needed a spare machine to mow our numerous acres of grass and said we could have it, as in for free!!
Well, we were more than happy to accept the offer and promptly put it to work. It has 600+ hours on an 18 hp Kohler engine but seemed to be running strong - for about three or four hours. My grandson was mowing their front yard when the engine simply died. I "schlepped" it back to the shop and started looking for the cause. It would start - barely, and ran poorly but stall if I tried driving it. Cleaned and adjusted the carb but no change. Put in new plugs which helped just a little but still wouldn't drive let alone run the mower deck. Changed the ignition module because the spark looked weak. A bit better but still lacked power and still not firing on the left side cylinder. Finally did what I should have at the beginning and did compression test. Right side has 80+ lbs. The left side - nothing, zero. Removed the head and saw what I feared; the piston does not move when I bump the starter, GRRRR...
There is no more avoiding it; the engine has to come out. My guess is the con-rod may be broken. But to deepen the mystery, when I pushed the piston back about a half inch and bumped the starter, it moved back to where it had been. It seems like the crankshaft pushes the con-rod out of the way and just runs the opposite cylinder. End cap broke and fell off? So I need to pull the engine and get at the bottom to see if repair is feasible. At least it didn't punch a hole in the block. May have done internal damage though.
Bottom line - advice, cautions, short-cuts?
