Cub Cadet 1641
/ Cub Cadet 1641 #1
NeedHelp
I can run my cub cadet for a lengthy period of time without any problems as long as the mower deck isn't in operation. When I turn the mower on, the battery begins to run down. I have serveral suggestions as to what the problem is, but no two are the same. Any ideas?
/ Cub Cadet 1641 #2
sounds like, battery -or- voltage regulator -or- stator....Hang a meter on the battery check your voltage while running to see if your charging system is working
/ Cub Cadet 1641 #3
I have a 1641 and had a similar problem. I found frayed wiring near the PTO clutch which must have been causing a power drain when the clutch was energized (engaged).
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2002 Hyster C330B Tandem Smooth Drum Roller (A61572)
2002 Hyster C330B...
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
TANK MANIFOLD (A58216)
