Mowing cub cadet 125 1970
   / cub cadet 125 1970 #1
knk810
arlington hgts,ill
cub cadet 125
My tractor will start with a jump but won't stay running after a few minutes. Just rewired voltage regulator, but still no luck. Could it be the generator has gone bad? Any ideas?
   / cub cadet 125 1970 #2
You need to check it with a voltmeter. Normal battery voltage is 12.6 volts and when running the generator should show 13.5 - 14.5 volts at the battery. The tractor shouldn't stop running from generator failure unless the battery is very low like 10-11 volts.
Bob B.
ok, thank you for the tip...I really want to avoid sending out. going to get a voltmeter and charger today, hopefully that works
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2015 Ford E-350 Cutaway Van (A55973)
2015 Ford E-350...
Honda EM 6500 SX Generator (A55973)
Honda EM 6500 SX...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
