Cub 2185 Belt Question
/ Cub 2185 Belt Question #1
Ductape
Elite Member
Central New Hampshire
Kubota B3030HSDC
I've got a Cub 2185 with the 42" mower deck. It ate the belt that drives the mower deck via the PTO. I do not have an owners manual, and I'm hoping someone can give me a part number and / or belt size so I can look for a belt locally. I'm guessing an aftermarket belt number might be easier to cross reference than a factory part# ?
If anyone can help me I'd greatly appreciate it. :thumbsup:
/ Cub 2185 Belt Question #2
check out cub cadet.com and look under parts. theyll have everything you need to know about your machine.
I appreciate the suggestion, though I don't seem to be having much luck. It may be that I'm not computer savvy enough, but I found illustrated parts diagrams for my tractor there......... but when I try the 'attachments', it lists none. And, under tractor categories, there is no choice for 'belts'. I also punched in the mower deck model number and nothing comes up.
I just realized my mower deck is a 46", not 42" as I originally stated.
/ Cub 2185 Belt Question #4
I think your 46" deck model number is 190-300-100 if so here's where I uploaded the operators manual. 46_deck_772-9031a[1].pdf[1].pdf
The Cub PTO to deck belt number for this deck is 754-3055A which is a B section belt 112.4" long. The Gates cross reference is 6615BR
Thanks for the help. The tag on the deck says: LT Deck 300 190
I should be able to find a Gates belt locally no problem.
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
Skid Steer Hitch Plate (A65640)
Skid Steer Hitch...
Saltdogg by Buyers, Slide in Spreader Box (A62679)
Saltdogg by...
(INOP) MCCORMICK FARMALL SUPER A TRACTOR (A64277)
(INOP) MCCORMICK...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
