cub 2150 problems
   / cub 2150 problems #11
i can get the starter to spin if i put a screwdriver between the two posts on the solenoid
it wont turn the tractor over just spins, and its a new starter
Sounds like your starter is bad. When you jump it like that you are bypassing all the safety switches. If the engine isn't turning over, then either the bendix isn't coming out of the starter, the bendix teeth are stripped, or the teeth on the flywheel are stripped (HIGHLY unlikely).
   / cub 2150 problems #12
any more ideas?
If you are not getting enough amperage to the starter it will just spin... you will need full current to the starter to engage the bendix. Check all connections pos and ground! Load test the battery with a battery tester!
If for some reason you have the battery hooked up backwards it will spin the starter backwards and the bendix will not engage...
To test switches use a volt ohm meter... ohms scale and check for continuity on and off. You will have ohms or no ohms...
   / cub 2150 problems
ok i put a jump wire in for the seat switch, i cut out the brake switch and wired those all together. and i took out the pto relay and jump with a small wire. the solenoid ontop of the starter has the red power wire from the battery, the blue wire in pluged into the stem, and the battery ground wire is bolted to the block. now still nothing, i know the pto switch works, because it clicked the pto shaft off and on, before i popped the fuse :rolleyes:
i took pictures for you to see but i am not sure how to get them up on here
i tell ya, i am about ready to put the wheels back on, and roll it over the bank. i am trying to convince the wife to let me just take it to a shop but not having to much luck there. she keeps telling me i have the deere to run...... females they just dont get it :cool:
   / cub 2150 problems #14
A volt ohm meter and a test light would have been my first choice before cutting wires... sounds like you are doing more guessing than actual testing. :rolleyes:
   / cub 2150 problems #15
Did we check that battery yet?
   / cub 2150 problems
yes the battery is fine. the test light idea was fine, the seat switch was torn apart when i got the tractor, and i pulled the brake switch out after it did not test, once under the tractor i seen it was being pushed in, but i tested it anyhow. i just ordered one of those off ebay. so i figured until it got here i would try this way. always have solder and shrink tubes! :eek:
   / cub 2150 problems #17
I have the SAME problem! Any resolution or solution yet?
:confused2:
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2016 Freightliner Bucket Truck (A55973)
2016 Freightliner...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
