Cub 1863 Broken Trans axle mounting bolts
   / Cub 1863 Broken Trans axle mounting bolts #1
johnf1951
Bullock, North Carolina
Ford 1210
My dealer says that this is a common problem. Anyone else had this problem? Was it Difficult to fix.
   / Cub 1863 Broken Trans axle mounting bolts #2
Do you mean the bolts that attach the frame to the rear end?
Curt
   / Cub 1863 Broken Trans axle mounting bolts #3
my 2182 broke the mouting bracket
   / Cub 1863 Broken Trans axle mounting bolts #4
We have had to put stronger bolts as well as extra reinforcement into that area to keep them in place. When pulling heavy loads they can give problems and it is wise to watch them as the more room they have to move the more problem they will be.
To call it a transaxle? That is wrong as it is one of the strongest axles ever put into a garden tractor.
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
20'x30' All Steel Carport (A53316)
20'x30' All Steel...
Newman Tractor 12in Excavator Digging Tooth Bucket (A55787)
Newman Tractor...
1999 GMC C6500 Service Truck (RUNS) (A50775)
1999 GMC C6500...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
60 Gallon Air Compressor (A55787)
60 Gallon Air...
