CTL - Washing out the belly pan.
/ CTL - Washing out the belly pan. #1
JRP
Platinum Member
South Texas
Kubota M6800
When i bought my T190 machine used it had 3" of mud in the belly pan. Took a while to scrape it out. Now is is full of trash and hydraulic oul.
What is the best way to clean this area? I see something like steep ramps and the machine driven up a ramp, so the junk flows out the back. Then use a pressure washer.
What works best?
/ CTL - Washing out the belly pan. #2
There are round or oval shaped plates in front corners of the lower frame to take out for cleaning. You may need to do both front end high and rear end high to get it cleaned out. Note: the engine platform sets higher than bottom of the frame (fuel tank is under engine) so when rear end high some water and debris stays in the bottom rear of frame.
