CTAndersom
   / CTAndersom #1
CTAndersom
Ashland, Alabama
John Deere baler
Needing help for a John Deere baler. I need to repair Flexco alligator rivet fasteners. Unable to remove pins
   / CTAndersom #2
:welcome:
:tractor: I'm going to move this thread over to our John Deere section for you.
   / CTAndersom #3
:welcome:
To the TBN forum CT. Glad that you joined with us here. I am sure that someone will be able to help you.
Which side of Ashland are you on? I married a Baker girl from Lineville. Maybe you know Albert or Earl?
   / CTAndersom #5
Welcome to TBN
Which pins are you referring to? The pin that keeps both halves of lacings connected or the pins that hold lacings to belts? If it's the one that hold lacings to belt correct method is to cut belt off just behind lacing then install new lacing utilizing the correct tool. Belt to be cut off square so belt will track straight
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2024 Kearney 7'x20' Trailer (A50123)
2024 Kearney...
CAT Skid Steer (A50322)
CAT Skid Steer...
2006 Acura RL Sedan (A51694)
2006 Acura RL...
2019 Ford F-350 XL (A50123)
2019 Ford F-350 XL...
