Backhoe Ct440 with backhoe
/ Ct440 with backhoe #1
ditchdigger78
Montana
Ct 440
Does anyone have a bobcat backhoe on a bobcat ct440 that has a cab. I have herd mixed info,some say the cab is in the way of the seat on the backhoe. Thanks.
/ Ct440 with backhoe #2
I haven't seen one on a cab tractor but imagine the seat is close, you would be resting your back against the window. Couple weeks ago I read in the Kioti forum that there are 1 or 2 brands of backhoe Kioti specifies Do Not install on cab tractor. I think that is becasue the seat will hit the window.
/ Ct440 with backhoe #3
Update on this question. I was reading through some material at dealer, Bobcat recommends removing the back window when the backhoe is installed.
/ Ct440 with backhoe #4
If you did not purchase the backhoe yet i would go with a woods ground breakerX over the bobcat backhoe. I could of went with the woods but went with the bobcat on my ct450. I have 120 hours on my machine and had to have all my seals replaced on backhoe already. The dealer told me they have a poor seal setup on the cylinder. I also heard the cab and backhoe dont fit. Thats why you never see them setup like that at dealers.
/ Ct440 with backhoe #5
I have the Bob Cat hoe....never heard of the seals being bad.
/ Ct440 with backhoe #6
I have a bobcat 9 hoe since 2009 and have many hours of use on it and have to say no leaks what so ever. And yes they do work fine on 4 series cab tractors, no problems with seat clearences. I once was told there was a different mounting bracket used with cab tractors...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Deutz DX140 Tractor (A66285)
Deutz DX140...
(5) 3" X 16" HYD CYLINDERS (1) 3" X 12" HYD (A64280)
(5) 3" X 16" HYD...
2010 INTERNATIONAL PROSTAR + DAY CAB ROAD TRACTOR (A64276)
2010 INTERNATIONAL...
Land honor Mini Skid Steer (A60352)
Land honor Mini...
