Backhoe Ct440 with backhoe
/ Ct440 with backhoe #1
ditchdigger78
Montana
Ct 440
Does anyone have a bobcat backhoe on a bobcat ct440 that has a cab. I have herd mixed info,some say the cab is in the way of the seat on the backhoe. Thanks.
/ Ct440 with backhoe #2
I haven't seen one on a cab tractor but imagine the seat is close, you would be resting your back against the window. Couple weeks ago I read in the Kioti forum that there are 1 or 2 brands of backhoe Kioti specifies Do Not install on cab tractor. I think that is becasue the seat will hit the window.
/ Ct440 with backhoe #3
Update on this question. I was reading through some material at dealer, Bobcat recommends removing the back window when the backhoe is installed.
/ Ct440 with backhoe #4
If you did not purchase the backhoe yet i would go with a woods ground breakerX over the bobcat backhoe. I could of went with the woods but went with the bobcat on my ct450. I have 120 hours on my machine and had to have all my seals replaced on backhoe already. The dealer told me they have a poor seal setup on the cylinder. I also heard the cab and backhoe dont fit. Thats why you never see them setup like that at dealers.
/ Ct440 with backhoe #5
I have the Bob Cat hoe....never heard of the seals being bad.
/ Ct440 with backhoe #6
I have a bobcat 9 hoe since 2009 and have many hours of use on it and have to say no leaks what so ever. And yes they do work fine on 4 series cab tractors, no problems with seat clearences. I once was told there was a different mounting bracket used with cab tractors...
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61573)
2011 Energy...
Jeep Tailgate Theme Wall Decoration (A61574)
Jeep Tailgate...
2016 Ford Fusion Sedan (A61574)
2016 Ford Fusion...
2013 Bush Hog 296 6ft. Rotary Brush Cutter Tractor Attachment (A61572)
2013 Bush Hog 296...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
