CT440 creeps backwards
/ CT440 creeps backwards #1
Z RENCH
North Texas
09 Bobcat CT335,09 ct440,08 Kioti DK55, 10 DK45HST, 10 DK40HST, & an 09 John Deere 4720
My 09 CT440 creeps backwards when in gear without the reverse pedal being applied. Anyone know if this is a simple adjustment or something more serious:confused:
/ CT440 creeps backwards #2
sounds like a adjustment, have you checked to see im something is wedge in the linkage under the floor that is causing the peddal to be slightly depressed?
/ CT440 creeps backwards #3
You can adjust the center position of the pedal damper under the floor. The procedure should be in the owners manual.
/ CT440 creeps backwards #4
Lubricate, lubricate and lubricate. My CT230 did that FWD during the winter and was the grease point (too stiff). Worked in now...
Thanx for the tips guys, I guess I'll have to break out the manuel and the grease gun and get this thing fixed before I run into something:thumbsup:
Roll of Barbed Wire (A64119)
Roll of Barbed...
BALDOR INDUSTRIAL 15 HP MOTOR (A64281)
BALDOR INDUSTRIAL...
2017 Ford Box Truck (A62613)
2017 Ford Box...
Fork Extensions (A61572)
Fork Extensions...
2018 INTERNATIONAL LT625 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2018 INTERNATIONAL...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63688)
2006 Cadillac GM...
