CT440 creeps backwards
/ CT440 creeps backwards #1
Z RENCH
North Texas
09 Bobcat CT335,09 ct440,08 Kioti DK55, 10 DK45HST, 10 DK40HST, & an 09 John Deere 4720
My 09 CT440 creeps backwards when in gear without the reverse pedal being applied. Anyone know if this is a simple adjustment or something more serious:confused:
/ CT440 creeps backwards #2
sounds like a adjustment, have you checked to see im something is wedge in the linkage under the floor that is causing the peddal to be slightly depressed?
/ CT440 creeps backwards #3
You can adjust the center position of the pedal damper under the floor. The procedure should be in the owners manual.
/ CT440 creeps backwards #4
Lubricate, lubricate and lubricate. My CT230 did that FWD during the winter and was the grease point (too stiff). Worked in now...
Thanx for the tips guys, I guess I'll have to break out the manuel and the grease gun and get this thing fixed before I run into something:thumbsup:
2015 Ford Explorer SUV (A61574)
2015 Ford Explorer...
2014 Freightliner 114SD T/A Dump Truck (A61573)
2014 Freightliner...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 579...
Ford F800 (A63689)
Ford F800 (A63689)
2007 Ford Taurus Sedan (A61574)
2007 Ford Taurus...
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
