CT230 - Won't turn over
   / CT230 - Won't turn over
I should get a chance to work on it tonight. I will the battery using the volt meter and a resistor to make sure the battery is good. It should be though, it was new last year. I would think that if it were the battery, or even a cable the engine would at least try to turn over. I think I might try to just jumper the seat safety switch to see if that's the problem and I'll climb under and see if the hydro safety switch is fouled in any way. I bought some electrical contact cleaner and will clean all the contacts I can get to and also the key switch. We will see where we go from there.
Would someone be able to give me instructions on how to possibly jump start the starter to see if I can get it running?
Problem Solved :) I guess I should have looked harder the first time. I had actuated the foot pedal several times, back and forth and it seem to return to normal like it should have, so I just assumed it was fine. This evening, I did it again and heard the switch snap, and then it didn't'. Crawled under to find a thorn stuck between the switch and the plate it actuates on. The pedal was moving freely, but the switch was stuck. Moved the thorn, and problem solved. Glad it was something so basic, just wish I had found it the other day.
Thanks for all the help fellas, helped me think out the steps I needed to take to fix the problem.
   / CT230 - Won't turn over #14
Well, there you go, a no cost fix.. cant beat that!
   / CT230 - Won't turn over #15
Glad you got it figures out. Just goes to show just because a lever/pedal is moving doesn't mean a switch is opening or closing like it should.
   / CT230 - Won't turn over #16
I have that happen a couple times a year. First time, I was in the middle of nowhere. It started raining about 5 min after tractor stopped. Not my best day.
   / CT230 - Won't turn over #17
I haven't had anything get caught in the travel pedal switch YET, but did find out a few months back that there is a "sweet spot" in the PTO lever that will cut out the safety switch but not move it far enough to light up the PTO On light in the dash. Now that is first thing I check any time it won't crank.
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2009 IC Corporation PB105 School Bus (A55973)
2009 IC...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
KUBOTA 80" QUICK ATTACH BUCKET (A51406)
KUBOTA 80" QUICK...
2000 FORD F-650 SUPER DUTY (A58214)
2000 FORD F-650...
