CT230 battery size
/ CT230 battery size #1
azop
My CT230 won't hold a charge and requires a jump start every time I use it. The battery is the original Bobcat battery and I don't see any markings on what size it is for replacement. What CCA should I get?
Thanks, I found on the battery size 24, would a 34 work?
/ CT230 battery size #6
Mine was group size 24. I just replaced it with an optima blue top hoping I would avoid any of the acid leaking issues that I had in the past. The cold cranking amps on the Optima were far higher than the stock bobcat battery I had in there. Have only had it in there about a month but so far no problems. It fit right in.
/ CT230 battery size #7
I recommend an AGM (absorbent glass mat) which is a non liquid dry cell. It's a heavier, more expensive battery but it will never leak and never freeze. Worth the extra cost by far.
/ CT230 battery size #8
MY 2011 group 24 on my CT 235 is still going strong - its the positive cable connection that eroded out. Thin copper ring connected to the terminal. Cheap
/ CT230 battery size #9
Anyone have a specific AGM battery that they recommend, and a source?
/ CT230 battery size #10
I bought a Optima from advance auto. It Fit well and has worked well so far and no more leaking acid. It has only been in about 2 months.
2022 John Deere Z720E Zero Turn (A63116)
2022 John Deere...
2022 John Deere 5055E (A62177)
2022 John Deere...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
JOHN DEERE 8330 TRACTOR (A63291)
JOHN DEERE 8330...
2006 CHEVROLET 2500 SERVICE TRUCK (A63291)
2006 CHEVROLET...
2025 Swict 84in Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
