CT 235 PTO HP testing
/ CT 235 PTO HP testing #11
The CT235 would turn a 5' rotary cutter really good.
not specific to Bobcat- but some dealers reportedly have pto mountable dyno's to verify a tractors horsepower output.
Have seen another post where the owner thought the tractor was producing well over what it was rated- in one case the pto was outputting more than 10 hp more than what it was rated.- i am sure that owner was pleasantly surprised...
you can also check Tractor Data- and it sometimes has links to Nebraska tractor test labs here- Nebraska Tractor Test Reports | Nebraska Tractor Test Laboratory | University of Nebraska-Lincoln
they do have the CT-450 listed but that is all...?
Hope this is helpful...
Do you remember what kind of tractor this was?
/ CT 235 PTO HP testing #12
Yes -it took me a little while to remember, but it was a Dong Feng 554 from a post on ( pro boards- Chinese tractor World Forums) pretty sure the tractor is a 55 HP rated tractor and it produced 70 Hp according to the owner, here is the quote-
I got 8.5 hrs on tractor now, so I thought I could safely dyno test it. I warmed it up good, then put it on dyno. It produces 70 HP on PTO at 1000 RPM. I was very impressed. NO SMOKE or OIL LEAKS. I spent about 3/4 hrs on dyno at varying loads and speeds...should be good for the engine break-in.
or see the thread here:
New DF 554 on order | CHINESE TRACTOR WORLD FORUMS
Good looking chinese tractor -although being an 08 I doubt that they are importable unless tier 4 capable
/ CT 235 PTO HP testing #13
that would be cool if someone had there's tested I have the CT 225 and I'd be willing to bet engine horsepower is it 28 horse and PTO horsepower higher than rated. I wouldn't even know where to start to get it tested.
/ CT 235 PTO HP testing #14
I bet he was happy with those numbers.
/ CT 235 PTO HP testing #15
Yep- i know I would be.
i think it has something to do with the engines being run for 12 hours @ the HP # they rate them at and also IIRC the YTO engine in that tractor is a larger displacement than most in the 55 hp class
tman
As far as getting it tested i do know i read at least of one member on TBN who thought their tractor wasn't making the power it was rated @ and they had the dealer test it on a dyno and they said it was within specs... so i would guess that at least some of the larger dealers would have a pto dyno...
So folks know it will run a Hesston 4450 with no issues
John Deere 6125R (A60462)
John Deere 6125R...
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A61568)
1999 Sterling...
2011 ORTEQ TANK MANIFOLD (A60736)
2011 ORTEQ TANK...
2019 LGMG AS1932E ELECTRIC SCISSOR LIFT (A59823)
2019 LGMG AS1932E...
