CS2510 - PTO and movement cause stall
/ CS2510 - PTO and movement cause stall #1
neal1199
Kioti CS2510
Hi All - I have a 2016 Kioti CS2510. It quit on me while moving mulch yesterday, CEL light came on and it stalled. I can start the tractor, it will stay running and idle, and I can move the bucket up and down and move the throttle up and down. The minute I engage the PTO it will stall, and with maybe 10 seconds of trying to move forward or backward it will also shut off. Any idea how I can diagnosis the issue? Nothing leaking, all hoses are intact.
Thanks
/ CS2510 - PTO and movement cause stall #3
Thanks
Mine did that while I was bush hogging, found a loose wire on the PTO Lever safety switch under the fender
2023 MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
2023 MORBARK WOOD...
FORD 3000 TRACTOR (A60430)
FORD 3000 TRACTOR...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
HUSTLER RAPTOR SD ZERO TURN LAWNMOWER (A60430)
HUSTLER RAPTOR SD...
UNUSED RAYTREE RMT48-48" HYD TRENCHER (A60432)
UNUSED RAYTREE...
