CS2410 mower/backhoe valve
/ CS2410 mower/backhoe valve #1
mtbitt
Apollo
Kioti CS2410
I have a Kioti CS2410 with FEL, mid mount mower, and backhoe. Somewhere I found where someone had come up with a way to install a valve to switch from backhoe to mower lift without switching the lines behind RR wheel.
I have been unable to find it again, and am thinking I must have just dreamed that I saw it online.
Anybody know how this could be done? I just have not had time to sit and try to figure it out.
Thanks! Mark
OK, thanks for looking at my post. I thought for sure someone had made something up to modify the hydraulics. I will figure it out one day when I get time.
/ CS2410 mower/backhoe valve #3
Actually, your BH requires one supply hose and if two hose unit, the other hose goes to tank.
Your BH valve supplies flow in one direction.
You could plug your mower cyl into one of the BH cyl ports.
If you put a diverter valve on one of the BH cyl ports you can use the diverter below, and switch operations using a toggle switch to switch from BH to mower lift using the BH valve..
Thank you! I will look into a diverter valve as soon as I get a chance. I have been working 12 hour days, so not much time to do anything right now. You have me headed in the proper direction I believe.
