Crushed asphalt pad?
/ Crushed asphalt pad? #1
JMER817
Platinum Member
Grass Lake, Michigan
John Deere 4120
I'm looking for an economical option to concrete for a 24 X 24 size basketball court for the kids. Has anyone tried crushed asphalt (Asphalt millings)? I can get the material that I need for around $250. Having someone do the concrete will run me around $2K.
/ Crushed asphalt pad? #2
I have a parking area with it but wouldn't want to use it for a basketball court. It doesn't pack down firm enough. Concrete would be your best bet.
/ Crushed asphalt pad? #3
Basketball on a gravel pad is hard on players and on ball
I would go with concrete pad also
/ Crushed asphalt pad? #4
The asphalt millings that I have are not good for playing anything on. Like BigBoyToys said, they don't pack down. I also have a driveway with 21aa crushed limestone that I think would be fine for basketball. The limestone will kick up though, so expect to grade it and tamp it occasionally.
When I was a kid, we had a pea gravel driveway and I hated it for basketball.
This might interest you
Sand & Gravel from Al's Trucking & Building Supplies, Inc. Fenton, Michigan
/ Crushed asphalt pad? #5
Not what you want to hear but I agree... maybe you can make the concrete forms and save a few bucks?
/ Crushed asphalt pad? #7
crushed asphalt is better than gravel, but concrete is best.
/ Crushed asphalt pad? #8
Is concrete more expensive than regular asphalt?
/ Crushed asphalt pad? #9
I used to play a lot of basketball on all types of surfaces. From hardwood, composites, concrete, hot rolled asphalt, and crushed asphalt and worse. It seems that over time asphalt flat tops seem to erode due the ground underneath settling or roots or chemical spills, etc. If you want it to last... go concrete! Nothing worse than not having confidence in your footing while playing hard. Sprained ankles playing hoops were my bane.
/ Crushed asphalt pad? #10
Check the cost between concrete, and a "millings" base with a thin asphalt (pavement) top coat for the kids. If that's all it's going to be used for, 2" compacted down to 1 1/2" should be fine.
If you get some "newer" millings that still has some asphalt in it that hasn't evaparated out, and place it in the middle of the (hot) summer and roll it, it's hard to beat for a driveway, not so much for a bb court.
/ Crushed asphalt pad? #11
I recently built a boat trailer parking space using crushed limestone as a base topped with "crushed" asphalt. The crushed asphalt was "millings" crushed to less than 3/8" in size. I rolled it with a 5000 lb roller and really liked the results.
/ Crushed asphalt pad? #12
My experience with crushed asphalt is that it is best as a top coating that doesn't last very long. It has not strength, so it lasts as long as what you put it over. If just placed on dirt, it will fail pretty quickly. If placed over compacted road base gravel, it does ok for a while, but then starts to fail. In my opinion, it is pretty much junk and not worth the time or money to mess with.
/ Crushed asphalt pad? #13
Crushed asphalt laid down at the proper depth and properly compacted should give results equivalent to or better than the same amount of crushed gravel.
/ Crushed asphalt pad? #14
True... But bouncing a bball on it after a few years probably won't be pleasant.
Tires and Rims (A65640)
Tires and Rims...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2015 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2015 INTERNATIONAL...
17394SFL (A61568)
17394SFL (A61568)
YALE FORKLIFT (A63291)
New/Unused Quick Attach Hydraulic Rock Hammer (A65583)
New/Unused Quick...
