Crush Washers - Aluminum, Copper, or Rubber?
   / Crush Washers - Aluminum, Copper, or Rubber? #1
ljplum12
Plano, TX
None
I've got some cracked and leaking washers on a couple banjo bolts (on the diverter valve). OEM is rubber, is it better to keep them rubber, or would copper or aluminum be an improvement?
   / Crush Washers - Aluminum, Copper, or Rubber? #2
If it's made for a rubber o-ring then rubber, if you can get a copper crush washer on it go copper.
The replacement part I found is a washer, which leads me to believe it's not meant to use an o-ring.
   / Crush Washers - Aluminum, Copper, or Rubber? #4
If you look closely you'll see that the neoprene washers are steel reinforced. You can replace them with new of like kind or use copper. Aluminum is ok, put copper is preferred. If there is a recess in the banjo fitting then you have to use an O-ring.
   / Crush Washers - Aluminum, Copper, or Rubber? #5
I would use rubber and be sure not to overtighten.
Adams Tender / Magnolia Trailer (A53473)
Adams Tender /...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
2023 PETERBILT 389 TANDEM AXLE SLEEPER (A53426)
2023 PETERBILT 389...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
