Crush Washers - Aluminum, Copper, or Rubber?
   / Crush Washers - Aluminum, Copper, or Rubber? #1
ljplum12
Bronze Member
Plano, TX
None
I've got some cracked and leaking washers on a couple banjo bolts (on the diverter valve). OEM is rubber, is it better to keep them rubber, or would copper or aluminum be an improvement?
   / Crush Washers - Aluminum, Copper, or Rubber? #2
If it's made for a rubber o-ring then rubber, if you can get a copper crush washer on it go copper.
The replacement part I found is a washer, which leads me to believe it's not meant to use an o-ring.
   / Crush Washers - Aluminum, Copper, or Rubber? #4
If you look closely you'll see that the neoprene washers are steel reinforced. You can replace them with new of like kind or use copper. Aluminum is ok, put copper is preferred. If there is a recess in the banjo fitting then you have to use an O-ring.
   / Crush Washers - Aluminum, Copper, or Rubber? #5
I would use rubber and be sure not to overtighten.
(INOP) FORD 8N / 9N TRACTOR (A51247)
(INOP) FORD 8N /...
UNUSED CFG INDUSTRIAL QK18R EXCAVATOR (A51247)
UNUSED CFG...
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
JOY G185XS PORTABLE AIR COMPRESSOR (A51248)
JOY G185XS...
UNUSED FUTURE JBD 32" MIXING BUCKET (A51248)
UNUSED FUTURE JBD...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53473)
2020 New Holland...
