cruise control does not work on my TC 40da
   / cruise control does not work on my TC 40da #1
nh621
When I first bought my tractor it worked fine but it doesn't now. I've tried a couple differnt things to see if it would work but nothing yet.
   / cruise control does not work on my TC 40da #2
Does it hold the speed a little then have it drop off, or does it not work at all? Do you have a green light on the switch that goes on when engaged?
The cruise control is an electromagnet that energizes on the hydro plate and stops it from swivelling. Did a branch swing up and disconnect one of the wires? Is the plate/magnet covered with grease? - try some carb cleaner on the magnet/plate. Tell us what you have tried/checked.
   / cruise control does not work on my TC 40da #3
nh621; Do a search for "Sometime cruise control". It's a thread I started about the same problem your having, and how I fixed it on my TC35DA. Jinman even included some good drawings on it. The cruise on all three class III boomers are the same. /forums/images/graemlins/grin.gif
   / cruise control does not work on my TC 40da #5
Froggy; That's the post!! I owe apologies to DocHeb tho, It was he that posted the diagrams. /forums/images/graemlins/blush.gifI went back and read that old post!
nh621; You'll find on this site that there's a wealth of info and someones always willing to help you out. Welcome to TBN. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / cruise control does not work on my TC 40da #6
</font><font color="blue" class="small">( I owe apologies to DocHeb tho, It was he that posted the diagrams. )</font>
Aw shucks! I was just beginning to enjoy your giving me credit for something Chris did. /forums/images/graemlins/laugh.gif
The light will come on but only while you are holding down the button. It does not work to hold speed at all. I haven't had time to look at it to see if there are any wires undone.
Thanks
   / cruise control does not work on my TC 40da #8
Will the cruise control work if you persistantly hold the rocker switch down (and keep the green indicator light lit)? If it works while doing this the switch is defective.
No I tried that also, it doesn't make a difference.
   / cruise control does not work on my TC 40da #10
</font><font color="blue" class="small">( Will the cruise control work if you persistantly hold the rocker switch down (and keep the green indicator light lit)? If it works while doing this the switch is defective. )</font>
Chris, this is starting to sound like the brake switch is misadjusted since the light goes out. It could also be the cruise relay or diode if I remember the circuit correctly. The easiest check is the brake switch and I think I'd look there first.
2023 Yamaha YXZ 100R SS (A51573)
2023 Yamaha YXZ...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
Deere 9965 Cotton Picker (A52748)
Deere 9965 Cotton...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
