Crossover Relief Value
/ Crossover Relief Value #1
450
New Member
Fairbanks, Alaska
Branson 3725CH
What is the most common crossover relief value people are using to install on a snowplow for tractor use? I am looking to covert a truck snowplow for use on a tractor and wondering what crossover relief valve to use for the angling of the blade. Thanks for any info.
/ Crossover Relief Value #4
I have the one from Surplus Center mentioned;works very well and is a must for a snow-plow.
Thanks for the info guys, I will order one of those when I get everything else built. From looking at the diagram ports B&D would go to plow cylinders and A&B would be where the rear remote hoses would hook up. Correct? This will be a set-up for use next winter so I have plenty of time. Thanks for the help again.
It is a crossover relief valve in case of a sudden surge in hydraulic pressure. It’s a safety device in case you hit something hard with your plow blade. It bypasses fluid from the high pressure side to the low side.
/ Crossover Relief Value #9
Gotcha...thanks...
KennyD,
I looked at the one on your site and it says Maximum Flow: 8 GPM Max. Is that the only crossover relief valve you sell? The one listed above is Maximum Flow: 30 GPM if I remember right. Also, another big issue for me is do you ship to Alaska and if so what method do you use? Thanks
/ Crossover Relief Value #12
450, since your only operating a plow with 2x8 or 2x10 cylinders, max flow is really of no great concern, especially since it’s intermittent use.
Yes, we ship to Alaska all the time, we use USPS medium flat rate boxes and charge $13. We can fit plenty other stuff in that box too.
What tractor/loader do you have?
PORTA POTTY (A68842)
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
PALLET OF LIFTING STRAPS (A68842)
PALLET OF LIFTING...
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61572)
2011 Energy...
2023 Polaris Ranger 4x4 Gas Utility Cart (A66734)
2023 Polaris...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
