Cross Referencing O-Rings
/ Cross Referencing O-Rings #1
JoelD
Windham, NH and York, ME
Kioti LK3054xs TLB, 2004
I need some o-rings for my backhoe (Kioti 2376), is there a way to figure out the size of an o-ring so I can find generic o-rings?
In some cases Kioti does not sell or list part number for some of the O-rings I need, rather an entire "sub assembly" totaling hundreds of dollars, when all I need is the O-ring.
These for for inside my nimco control valve assembly.
Much appreciated,
Joel
/ Cross Referencing O-Rings #2
Much appreciated,
Joel
Northern tool will have a sizer that looks like a cone and 1 for thickness. But you need to know what they are made of too.
/ Cross Referencing O-Rings #3
There are several charts online. It is the inside and outside measurements that determine size. Auto and tractor supply stores have size charts as well as hardware stores.
/ Cross Referencing O-Rings #4
Much appreciated,
Joel
Joel, my Kubota backhoe uses a Nimco valve also. Not sure which o-ring you need but a Kubota dealer can give you a blow-up of the valve assy. For what it's worth Kubota pt#04816-00120 was used in all of the spool valves. If you need the wipers, the part is RB401-70510. Hope this helps.
Much appreciated!
Will tear into it again soon and round up the o-rings I need and start the chase
All leads are appreciated!
I had two Kubita b6000e's loved those machines!
Had one with original loader and then mounted a frame mount backhoe that machine was cool
I even had the pto reverser, original finish mower and tiller.
Joel
Just took a closer look at packaging of o-rings I purchased from dealer. They are labeled with size, 17.1x1.6-70.
Just ordered 25 on ebay for $15 delivered, versus almost $8 per from dealer. It was killing the dealer to charge me. Now I have all I need. How to figure out other sizes within the assembly, I've reached out to Nimco but no answer so far will try again.
Joel
/ Cross Referencing O-Rings #7
You are figure out the o-ring size from 2 measurements: the ID and cross section. Google o-ring chart, to cross reference from measurement to standard sizes.
Many places sell cone measurement tools to figure out the size.
Lines on the cone give standard sizes (ID) and notches on base find cross section.
That 17.1x1.6-70 is a metric o-ring. 17.1mm ID, 1.6mm cross section and 70 durometer.
Careful with ebay o-rings. Need to make sure the material is compatible with hydraulic fluid and durometer is close.
MUCH appreciated yes matched 70 rating
I will purchase cone cool tool to have
/ Cross Referencing O-Rings #9
I have found it to be worthwhile to buy o-ring kits. They are pretty cheap compared to just buying a few o-rings.
SAE o-rings come in - (dash) sizes. I bought a kit that has the -1xx and -2xx sizes. I think each kit was only like $15-$20
Agreed
I ended up using an 0-ring from an assortment I had purchased a bit ago to reassemble my backhoe
Solved my problem at least for the time being
I will find size of exact match as the factory o-ring is a bit flat sided rather than perfectly round edged
Thanks
Joel
/ Cross Referencing O-Rings #11
Dont know what you mean by "a bit flat sided"
Only o-rings I know of are square profile, quad rings, and standard o-rings. The "a bit flat sided" may just be the signs of a used o-ring.
I realize it sounds like an oxymoron but when new they appear to be not perfectly round on edge
And they are white and they feel softer than a typical rubber o-ring
These are the seals between the spool and the casing
They seem to turn soft and gummy with time and fail easily
I've replace all of them on the valve body and trying to find longer lasting and better made more affordable alternative
I posted picture on my other post about backhoe moving on its own
Joel
/ Cross Referencing O-Rings #13
I'm looking for some O-rings for my Kubota trator. I got stuck when I got to the durometer number. I found some listed with a durometer of 90 and others with a durometer of 90A. Looking on-line I can't find where the difference is explained.
Any help would be appreciated.
Thanks.
/ Cross Referencing O-Rings #14
No difference between a 90 and a 90a.
Durometer is measured with the shore scale. The shore scale has different levels, a A, B, C, D, etc Kinda like rockwell hardness has C, B, etc.
Orings are measured with the "A" scale. Sometimes they just omit the A from the literature
/ Cross Referencing O-Rings #15
Thanks. That was what I was thinking. Thanks for verifying.
2010 Case 580N (A60462)
2010 Case 580N...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
2016 Peterbilt 320 EZ Pack 40yd Front Loader Garbage Truck (A61573)
2016 Peterbilt 320...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2012 International 4300 Reefer Truck (A63689)
2012 International...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
