Cross Reference not as simple to find............
/ Cross Reference not as simple to find............ #1
bswiv
Palatka, Fl
CAT D5G, Kubota M8540, KubotaB2700
...........at least not one I actually understand.
So I'm going to ask what must be a recurring question.
Have a Challenger MT525 which has specifications for hydraulic oil of Permatran III CMS M1145.......where is a cross reference chart to find similar as I do not see it for sale around here?
/ Cross Reference not as simple to find............ #4
Go and have the people at NAPA or O'Reilleys check their catalogues. Otherwise - just buy the hydraulic fluid from your local MT dealer.
/ Cross Reference not as simple to find............ #5
It also crosses over to kubota udt....or jd-j20c.....
/ Cross Reference not as simple to find............ #6
Hydraulic fluid substitution is common and often necessary due to availability, and you can't go wrong if you buy quality. NAPA and any JD or Kubota dealer will provide quality hydraulic fluids for your tractor.
So yet again I've proven I'm not all that smart as the cross-referencing the cross-reference idea escaped my though process until someone pointed it out. The value of a bunch of folks being there to help demonstrated again.
Thank you
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
2022 EZ-GO ELITE...
set of 4 tractor trailer tires Roadforce (A63689)
set of 4 tractor...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
HEIN-WERNER 1TON TRANSMISSION JACK (A65643)
HEIN-WERNER 1TON...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
