Cross BYD valve (log splitter 1978)
/ Cross BYD valve (log splitter 1978) #1
jacob844
NEW TRIPOLI, PA
Kubota B2650 HST TLB Cab w/3rd fuction valve, (2) JD322
I have a 1978 log splitter with a cross valve, BYD single leaver. I have been using hydraulic fluid but wish to change to transmission fluid, which is the same that I use in my Western Pro Plow Isarmatic cable motor. Is it possible to mix fluids or must I drain the current system? My second question is the action of the pump... to the left actuates the ram; center is neutral and to the right returns the ram. When the lever is pushed to the left it (most of the time) will hang and allow the ram to return and then pop to the neutral position. This does not always happen and can be frustrating as I turn to place another log on the ram bed. Does anyone have an opinion as to this cross unit? Is this common or does it need to be repaired, maybe a seal kit or?
/ Cross BYD valve (log splitter 1978) #2
Welcome to TBN. :)
/ Cross BYD valve (log splitter 1978) #3
Hello & WELCOME to TBN!
I moved your thread to the Parts/Repairs Forum. :)
/ Cross BYD valve (log splitter 1978) #4
On the fluid change I would recommend draining and refilling your system.
On the valve it sounds like the "detent" is getting worn or dirty. Not sure on that model how easy or difficut it is to access this detent.
ROy
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
Adams Weight Hopper (A63688)
Adams Weight...
7888SFL (A61567)
7888SFL (A61567)
RAIN FLOW HOLE PUNCH, 3PT (A63291)
RAIN FLOW HOLE...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
