Crippled my DK45...again!
/ Crippled my DK45...again! #1
rd_macgregor
Prince Edward Island, Canada
Kioti DK45SC, Kubota B2650
Last summer, I managed to break the RF bevel gear case and shaft working in the woods. I got that all fixed up and working well for a couple of months, until yesterday, when I managed to do the same thing to the LF. This time, I even managed to do a bit more damage, shearing off the connecting end of the steering hydraulic cylinder and (I think) bending the threaded end of the tie rod.
My wife is considering banning me from taking my tractor into the woods anymore, but I hate to think of it as just a big, orange mower and manure mover. On the other hand, maybe I can parlay this setback into another piece of equipment, like a dozer, loader or track hoe.
I'm not keen on the cost of repairs, but the tractorless down-time will be a bigger burden, since I don't have another good way to move round bales to the horses.
The fun never ends!
Bob
/ Crippled my DK45...again! #2
Bob, ouch! Do you know what it was that you hit to cause that much damage?
/ Crippled my DK45...again! #3
Sounds like someone needs to weld up a custom skid plate for the front end so you're trashing strap & angle iron instead of driveline components on those rocks.
/ Crippled my DK45...again! #4
Wow, really! You are Dr. destructo. You have me beat, by a wide margin. I think you should go straight to tank and skip dozers.:D
We need pics! We'd believe you based on past experience, BUT it's TBN policy, no pics, it didn't happen.:confused3:
/ Crippled my DK45...again! #5
Are you related to Eric the Oracle by any chance?
/ Crippled my DK45...again! #6
... I think you should go straight to tank and skip dozers. ...
I think a dozer would be fine. Perhaps a D9:
I went out last night and took off the wheel. The only thing holding it all together now is the tie rod (the end of which is bent slightly), since the bevel gear case and shaft are broken and I sheared off the outboard end of the steering hydraulic cylinder. I also noticed that I put a pretty sharp dent in the steel wheel right at the rim. Thi$ repair will be even more co$tly than the la$t.
I'm not sure why this happened once, much less twice, though I have a couple of plausible theories. My latest is that I was pushing and lifting while the front wheels were turned to the side in a location where the tractor couldn't actually turn. This would put tremendous lateral stress on the bevel gear housing. Of course, this doesn't really explain why this should suddenly happen now (twice!) after 8 years of doing this kind of work...just lucky, I guess.
"No pics, it didn't happen" I wish it was that easy to undo!
I took a couple of pics, but they are on my camera at home; I'll try to remember to upload one later.
Bob
/ Crippled my DK45...again! #9
These tractors are so well-built have such strong capacities anymore we often find ourselves thinking they're invincible. I think that we often try something that is questionable to the tractors abilities and get away with it a few times and think that it must be okay but in reality it's just a matter of time before we break something that way. Unfortunately no matter how strong their built we can find a way to break something. Thank goodness for TBN. And good luck.
I took this pic Monday afternoon and it shows the major broken parts. I now have the tire off, so can probably get a better angle to document the damages.
Note that the only thing holding the wheel onto the tractor is the tie rod; every other connecting bit is broken!
Bob
/ Crippled my DK45...again! #11
Bob
So noted!:eek:
An update: Out of service for 6 weeks, but all the parts finally came in and we were able to get a guy with a portable welding rig back into the woods to weld the steering mount back onto the end of the cylinder on Saturday. It was kinda chilly getting everything back together out in the wind, but it seems to be functional again...I'm expecting to do a lot more of my work on trails manually in the future, though (under orders from SWMBO).
Its about time to take off the tooth bar and hook up the snowblower...
Bob
/ Crippled my DK45...again! #13
Geez man you gotta go buy a lottery ticket. You're due some good luck. By the way, sorry you can't borrow my tractor! LOL
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
(4) Wheels and Tires (A65640)
(4) Wheels and...
Fellabuncher Dangle head, PARTS ONLY (A62679)
Fellabuncher...
Shoup John Deere 918 Poly for Platform (A65640)
Shoup John Deere...
