Creating my Slightly Different Chicken Coop
   / Creating my Slightly Different Chicken Coop #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
Two years ago my wife was given some chickens and I built her a 10x20 chicken coop. We're now getting about 16 eggs a day from them. Last year she was given guineas and needed a coop to keep them in short term, so I built her a 12x12 coop as part of our horse barn. After releasing the guineas one at a time so they would stick around, she bought a couple dozen broilers and raised them there before we butchered them.
Last month she decided she needed to have silkies and several other breeds of chickens. Even more important, she wants roosters to breed them. We've learned that roosters are pure evil and that they have to be confined and separated from other roosters, and only have short periods of time with the hens. If left with them too long, they tear up the hens with their spurs.
The plan evolved from multiple chicken tractors to combining them all into one circular chicken coop with 8 pens laid out similar to the spokes of a wheel.
Below are two sketches I drew up on graph paper to get my dimensions figured out. There will be a 36 inch exterior door to get into the enclosed portion of the coop. There will be a separate door to each pen, laying boxes, waters with heaters for winter and feed. They will have a small door to go out to the open area that will be fully enclosed with wire field net and a door to get into that area from the outside. It will require over 40 posts and probably take me the rest of the year to finish if I'm lucky.
Last week, I measured it all out, marked where the concrete pad would go, and flagged the position of the posts. Then I set the forms and dug out the footings. The ground is very dry and hard, so I used my SDS Max rotary hammer with clay digging shovel bit in it to break through it. I set rebar and then went to lowes and bought sixty 80 pound sacks of readi mix concrete.
The next morning it rained, so I started mixing concrete at 1 pm. Probably the worse time of the day to do this with temps in the high 90's and the humidity very high right after the rain. I was literally raining sweat!!! It took 50 sacks.
This weekend I started trenching for my utilities. I want water and power to the coop. Power is coming from the house and is a fairly straight shot. Water is being tapped into from a line I have going across my garden. I dug it up with the SDS Max rotary hammer using that shovel bit to find it, then carefully used my backhoe to open up the trench ten feet in either direction. It's 3/4 pvc and to get a T onto it, I need to lift the pipe up enough to slide into the fitting.
While I'm at it, I decided to run five more water spickets to areas around the garden. One of them will be a 16 foot treated post that I will turn into a streetlight with a LED dusk to dawn light.
Here is the little silkie that is causing me so much work and money!!!! and my crazy wife in her baby chick room :)
   / Creating my Slightly Different Chicken Coop #5
   / Creating my Slightly Different Chicken Coop #6
We have about 60 chickens and the granddaughter got 12 from 4H to raise.
Very cool. I never heard of that before, but that's the idea I had to monitor and access each pen from one central location. Sometimes I wish I had an education to already know these things.
   / Creating my Slightly Different Chicken Coop #9
Looks very good. As usual your projects are spectacular Eddie. We used to keep silkies too, but it's too cold here for them in the winter. They are pretty neat looking.
   / Creating my Slightly Different Chicken Coop #10
Looks great and I learned something new. I did not know/never thought about getting a "clay digging shovel bit" for my SDS rotary hammer.
It is is off to Lowes/HD.
2017 FORD EXPLORER (A59823)
2017 FORD EXPLORER...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
1449 (A57192)
1449 (A57192)
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
