Creating a simplified Landscape Rake
   / Creating a simplified Landscape Rake #11
Eddie, one more thought for you. I don't know what size tractor you have, but I the photo show my 6' rake mounted on a Kubuta B2910 (30hp). I also use it on a NH TC24D (24hp). Both of those are small tractors. If you are using it on a tactor larger than 25hp, consider making a bigger rake for your jobs.
EddieWalker said:
My roads are a minimum of 30 feet wide to as much as 50 feet wide. Then there's the debris under the trees that I'd like to clean up.
It strikes me that a 6' rake is small for your roads. If you are running 30hp or more, go up to a 7' or 8 foot rake without hesitation.
Also, I think many people think of a rake as a light duty tool. Please do yourself a favor and don't skrimp on the steel structure. These rakes can be amazingly versitile tools, they can endure a lot of torque stress if you build it heavy enough. Entend your toplink and it can be used to aggressively tear up the soil and it does a great job of smoothing dirt/clay paths, shorten the toplink and you skim across the grass but gather the debris that is in the lawn. I found that a hydraulic toplink makes life easier and makes the rake more useful, but it also taught me that the rake is more useful than I originally thought it would be.
   / Creating a simplified Landscape Rake #12
Eddie, be careful of how you build your rake. Of course it makes a big difference what your pulling it with. If you are going to be using a little bigger tractor, I suggest that you build it heavy duty. Especially when you will be using it a lot of the time.
I bought a Midwest 8' rake myself and proceeded to twist and bend the channel iron that it was made of into a pretzel.:( So I rebuilt it with some heavier metal. I got new channel to hold the tines and welded that to a 4"x7"x 3/8" wall tube. I have had no bending since the rebuild.:) Here's a picture of it just after I was done with it, and I had the whole thing powder-coated.;)
Brian
   / Creating a simplified Landscape Rake #13
Brian
Brian powder-coating a rake huh, very nice idea. You sure beefed that rake up some.
   / Creating a simplified Landscape Rake #14
Mike, thanks for the comments. It was something that I had to do. Like Bob said, a lot of torque can be applied. I too was amazed at how versatile a landscape rake can be. It just has to be built to take the load that it's given.;)
Brian
   / Creating a simplified Landscape Rake #15
I made a light rake a few years ago out of some hay rake tines and a piece of 2 X 2 X .25 sq, tubing, and pivets on a 2nd piece of tubing that will slide in to a hitch I have for my tractor. The rake works great for sticks and I even use it to dehatch my lawn and works great for driveway maintenance. Total cost about $50.00. The rake is light duty and does not work good for large stones or logs, but then again the last time I looked I don't have any large stones or logs in my yard or drive way, so I guess it must have gotten them all out. :D
I picked up some steel today for the rake. One stick of 5X3 angle iron and one flat stick of 3/8X2 for $91. I bought 50 grade five 7/16 inch and a half bolts, nuts, lock washers, a new half inch bit and a pair of pins for $39.
The first picture shows the basic frame.
The second picture shows the hole drilling nightmare I have to deal with.
Eddie
   / Creating a simplified Landscape Rake #17
Eddie.....looks like you'll be wanting a Drill Doctor !
I have one, but I'm not very satisfied with it. I still prefer to use the fine wheel on my grinder and eye ball it. I drilled ten holes with the new bit yesterday and plan to drill a minimum of ten holes a day. I hate drilling, but know it won't get done on it's own. hahahaha
25 tines with two holes each means I'll be at it for another four days.
Eddie
   / Creating a simplified Landscape Rake #19
Eddy do you draw out a set of plans before you build something or is it all in your head. I tend the draw out my plans and measurements on paper 1st. I'm just curious
   / Creating a simplified Landscape Rake #20
if there ever was a job that needed this tool!
might almost be worth $40 at the local rental center
Stout Brush Grapple (A59814)
Stout Brush...
New Holland 650 Hay Baler (A53317)
New Holland 650...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2017 Ram 1500 Pickup Truck, V6, 4X4, Automatic Transmission, 212,570 Miles (A56438)
2017 Ram 1500...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
