Created a Flat Spot...
/ Created a Flat Spot... #1
teg
Super Member
nowhere
s
Wanted a new flat spot where we can park a friends camper. The area was mildly sloped so it didn't need much, about 2-3' fill at the low end. Used the tractor with a Box Blade, Rear Blade and finished off with the pulverizer yard tool (just for a seedbed). Used about 3 clock hours on the tractor and mostly a day to do it. Not too exciting :p but thought I would share.
Started out with ripper in the box blade... Hydraulic toplink was worth it... decided I need more weight (old crankshaft, chunk of steel and tied on a middle buster :D). Got it pretty close and decided to plant grass so I used the Yard Tool which gave a nice finish. Just noticed I didn't get photos of the rear blade cutting the inside ditch :mad:
It must be the camera angle...is it really level?
Nice lookin place!
It does slope off a little... does this angle look better? :) Wanted to make sure it doesn't become a pond :eek: I'll let it get rained on for a while and see if I need to adjust the angle. Also, it might compact more on the high side so I may have to add more fill. It's a start...
/ Created a Flat Spot... #6
Good job teg...thanks for sharing! :thumbsup:
/ Created a Flat Spot... #7
Great job Teg! You can always get some erosion mat to put down over the seed, if your worried it will wash before the seed pops.
/ Created a Flat Spot... #8
Are you going to compact it.??
What is the "pulverizer" that you speak of.??
Beautiful area.:thumbsup:
/ Created a Flat Spot... #9
Nice job and, as JDGreengrass already mentioned, beautiful area.
/ Created a Flat Spot... #10
Ah, yes that's better(bigger pic too). You will have to seed it with something that like heat, then follow up with a cool weather seed in a couple of months. Johnson & fescue grass are the main players here in E TN.
I had Rye Grass and Clover on hand... I normally cut down some pasture and spread that around. I'm going up this wk/ed and see how it held up.
I might plant soybeans... and make it a food plot :D
I drove on it as I move the dirt in place. Used the Truck a couple of times, too. Back and forth lots of times. It's worked for me before.
I have better photos of the pulverizer (this is a copy of the one above). It roughs up the dirt to plant seed. After using the scrape blade, the ground was too smooth, almost shinny, and hard packed.
Thanks, we kind of like it too :D
/ Created a Flat Spot... #13
Looks good, I like it!
James K0UA
DITCH WITCH 3700 TRENCHER (INOPERABLE) (A67714)
DITCH WITCH 3700...
COMBO PORTAPOTTY/TRASH TRAILER (A67714)
COMBO...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
2018 MACK CXU (PINNACLE) (A67714)
2018 MACK CXU...
Polaris Ranger 4x4 Gas Utility Cart (A66734)
Polaris Ranger 4x4...
2016 Toyota Camry Sedan (A66738)
2016 Toyota Camry...
