Crap my welder quit!
   / Crap my welder quit! #1
Mighty Dodge
The Hereford Zone, MD
JD 4200
I was working on a few projects when my old Lincoln G8000 quit. When I try to strike an arc I get very weak sparks. Tried switching amp setting and polarity. It senses 120 volts when I plug in a trouble light by revving up the engine but won't light it up. I pulled off the cover nothing appears to be smoked. Any ideas? Think it's worth fixing?:(
M.D.
   / Crap my welder quit! #2
Naw, Just buy the one I have on Ebay now. Later, Nat
Tongue in cheek!!!!!!!!!!!!
   / Crap my welder quit! #3
I'm not familiar with that unit.. but look for problem areas.. like disconnected field or bias resistor wires.
I had an old miller D?? series welder.. diesel powered.. and there was a wire on a spade plug that would come off and no power to welder or plugs till it was fixed.
Soundguy
Thanx for the replies...well one anyway.:D
I checked the connections, cleaned the slip rings, no change. I posted the problem on a couple of welding boards and got a few more suggestions that I'll check tomorrow. I suspect something on the circuit board smoked. I asked for help on Lincoln's support site they said I should have a reply within two business days....we'll see. This has put a real crimp in my project schedule.
M.D.
Found a bad connection on the field bridge rectifier. Replaced one connector, cleaned and put dielectric grease on all the connections...It works!
Thanx for all the replies.
M.D.
   / Crap my welder quit! #6
Glad you got it fixed, and posted the solution. That might help someone else in the future if they have a similar problem.
   / Crap my welder quit! #7
I'm pretty sure that is what mine was.. field.. etc..
Soundguy
   / Crap my welder quit! #9
Pics would be nice, so folks know where to look. Glad your back in business.
Sorry I didn't take any pics when I had it opened up. I don't know if they'd be useful anyway unless somebody else has the same welder. I would suggest that if anyone else has the same problem they check and re-seat all connections in the welder.
1993 Ford Ranger STX Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
UNUSED FUTURE 12' X 7' CONTAINER (A51244)
UNUSED FUTURE 12'...
TAKEUCHI TL8R2 SKID STEER (A51242)
TAKEUCHI TL8R2...
2019 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2019 UTILITY VS2RA...
Land Honor Skid Steer 3 pt Adapter (A50515)
Land Honor Skid...
John Deere turbo 6620 Combine with head (A52128)
John Deere turbo...
