Crankshaft Nut
/ Crankshaft Nut #1
recon
I have lost the nut that holds the fanbelt pulley on the front of my 2200. It looks from the parts manuals to screw onto the end of the crankshaft. I can slide the pulley on the shaft and it will run for a while but eventually spins itself off. I ordered an M30 nut from Hoye but it did not fit (too large) The diameter seems to be somewhere between 7/8 and one inch on the threads of the shaft. Any help would be greatly appreciated since it is rough trying to mow 5 acres without my tractor. Thanks
/ Crankshaft Nut #2
One inch in metric is 25.4 millimeters. That would be the best I can help you with trying to figure size. Hoye or one of the other dealers on here should be more helpful. If you have a metric socket set that could help with figuring out the inside diameter you need.
/ Crankshaft Nut #3
You need to measure the thread diameter in mm's and go to a specialty nut and bolt distributor or order from a place like McMaster-Carr, probably 24mm, 2 pitch, get 1 of each pitch.
/ Crankshaft Nut #4
I have several YM2200 parts tractor's with the nut on them.
Danny
PALLET OF MISC ITEMS (A67714)
PALLET OF MISC...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
Welcome to the Ranch Metal Decorative Sign (A64557)
Welcome to the...
1 PALLET OF CATALYTIC CONVERTS (A66091)
1 PALLET OF...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2022 Chevrolet...
12IN CENTRIFUGAL PUMP (A67714)
12IN CENTRIFUGAL...
