cranks but doesn't start
/ cranks but doesn't start #1
cadman70454
My wife's told me yesterday that the BX-24 wouldn't start. We just paid it off so I figured it was the battery at 48 months old. I went out with her this morning and she turned the key and the battery/starter turned the engine over just fined but it wouldn't start. After the third extended try at starting it, she said she thought it was one a malfunctioning safety switche. She fiddled with all the levers on the right side controls, turned the key and it started right up. Would a safety switch allow the engine to turn over but not start?
Lowell
/ cranks but doesn't start #2
No.
Could be just a coincidence, or maybe fiddling with some lever moved a wire harness that was shorting or not making a connection. Tough to diagnose now that it's started.
/ cranks but doesn't start #3
Sounds like a glow plug issue. Loose wire or one is burned out. You can check with an ohm meter.
/ cranks but doesn't start #4
The D902 engine uses an external fuel shutoff solenoid, so unless the solenoid or the fuel shutoff lever is jammed, if it cranks it should start. Check glow plug circuit for power. Also check to see if you hear clicking sound of lift pump also.
David Kb7uns
My wife spoke to the mechanic @ the dealer and he said give it some throttle when starting. She did that and it started right up.
Lowell
1960 IH Farmall Cub Tractor (A66285)
1960 IH Farmall...
40' Used Container, High Cube, Single End Doors (A62679)
40' Used...
2013 FREIGHTLINER CASCADIA (A65643)
2013 FREIGHTLINER...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
42in. Pallet Forks (A65640)
42in. Pallet Forks...
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A64553)
2025 Mower King...
