Crankcase vent
/ Crankcase vent #11
If your going to use muratic acid..Be certain that the front is clear..Put a lamp by the water pump and look from the front for the light..I had trouble and flushed it , waterwetter. the works. Then the front had some very fine material inside the screen that had restricted the airflow...Would have seen it first if i had used the light..Washed and light air pressure to remove--HAIR like material?? Where did that come from??Cured>
/ Crankcase vent #12
Did you back flush? I just went through all this with my 2210 getting a bit to warm. back flushing until it runs clear, fill with water, work it until hot, drain. take rad cap off and put a hose in it, take lower rad hose loose, crank engine and let run until all runs clear, I ran mine a good 15 minuted this way. oh of course keep hose running water constantly.
also make sure your fan belt is good and not slipping. I had to tighten mine up.
edit: I also thought my outer fins were clear, but they weren't and weird I noticed some hair like material as jonyyuma mentioned
/ Crankcase vent
I flushed and backflushed with a water hose. Ran some straight water until it got warm and dumped that. I suspect the radiator isn't transferring enough heat for a hardworking tractor. I'll clean it with some acid and do a good flush again before it gets unbearably hot here.
/ Crankcase vent #14
I would sure agree your cooling system needs to be doing the job. If these little Yanmars have a weakness it is not being able to tolerate overheating. That will get a head gasket pretty quick.
/ Crankcase vent #15
The overheating is/has been an issue when ran hard. It's progressively gotten worse. I changed the water pump and did a good flush last summer. I used distilled water, water wetter, and 1/3 antifreeze but it still gets hot. Once it's hot, it takes a long time to cool off. It has trouble transfering the heat. A few squirts from the water hose drops the temp to about a 1/4 of the guage after a few minutes of it evaporating. Ima try to flush the radiator with a mild mix of muratic acid before the summer hits down here. I can see through the fins at the engine, so the outside is clean.
I think your head gasket may be slightly blown or your radiator is slap crudded up inside.
As far as the rebuild, i would take the pan off and push the pistons out and rering them and put new rod bearings on it and call it good, i bet this will be all you need!
/ Crankcase vent #16
I think you mistyped, if you disconnect the lower hose while running you wont get any fluid to the tractor as it sucks outta the bottom? I was confused by your process and post but get the idea your saying.
/ Crankcase vent #17
WOW, i sure did, thanks for pointing that out, I meant the drain plug on the side of the tractor, its a bolt..
/ Crankcase vent
I removed and flushed/soaked the radiator with muriatic acid today. It was the only kind I could find...labeled 'Green'. It sounds like a weaker solution and isn't labeled with a %. I used it straight and filled the rad. up 3/4 full. Shook it violently then poured it out on a fireant bed. The crud and dark color suggested it worked. I did it a second time but let it sit this time for maybe 15 minutes. This time it had a slight milky coloration. Hopefully it got most of the scale out if it. Three good flushes with a garden hose and three good flushes to the pump side and I reinstalled it. I used distilled water, a little antifreeze, and a 1/3 bottle of water wetter.
The battery was dead so it's gonna spend the night on the charger and hopefully I can give it a whirl tomorrow. I've got about an acre and a 1/2 to till under for the garden this summer. That should be a good workout for the ol' 2000.
/ Crankcase vent
The acid seemed to have done it. Although it was 65 degrees here, when it normally would be pushing 90-100. I ran it as hard as possible and it never got over a 1/4 on the gauge. Stayed mainly in 2nd gear, WOT, and down around 2000 RPMs. Ran it like this for almost 2 hours.
At start up, the CC vent was blowing good. After it warmed all it was, the CC smoke petered off to just slightly blowing.
2007 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A62129)
2007 CATERPILLAR...
2005 DRAGON ROLL-OFF  TRAILER (A60736)
2005 DRAGON...
2011 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2011 DRAGON 150...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
2001 John Deere 6210 (A60462)
2001 John Deere...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
