Crankcase oil level rising
/ Crankcase oil level rising #1
B7200E
SE Kansas
Kubota B7200E
I have a mid 80's B-6200 hst, power steering and loader.
while I was checking my oil, I noticed the oil was farther up on the dipstick than it should be. I had recently added hydro fluid because I noticed I was having to push farther down on the hydro pedal to move faster. I drained the engine oil to the correct level. I ran the tractor for a couple of weeks than checked again and the level had risen again.
I looked at my parts manual and saw a oil seal around the hydraulic pump shaft.
Is that the only place where it is possible to mix hydraulic fluid and engine oil? Especially at that rate? I guess it could be from the powersteering somehow but I haven't looked into that yet.
I will fix this myself so taking it to the stealership is not an option. If I can rebuild the engine I can fix this problem.
Thanks in advance,
Jeff
/ Crankcase oil level rising #2
what problem? you got it nailed already and just need the seal/time/ beverage of choice and you'll be back in tractorin bliss........... /forums/images/graemlins/laugh.gif
/ Crankcase oil level rising #3
</font><font color="blue" class="small">( . . .
Thanks in advance,
Jeff )</font>
As strokerduster says, you've got it figured out. The power steering pump could also be a souce. But, the main culprit is likely the hydraulic pump with its greater volume.
2022 EZ-GO ELITE...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
2022 EZ-GO ELITE...
Landhonor Quick Attach Landscape Rake (A66408)
Landhonor Quick...
2012 Kenworth T300 17ft. Cab and Chassis Truck (A64194)
2012 Kenworth T300...
