Crankcase oil level rising
/ Crankcase oil level rising #1
B7200E
SE Kansas
Kubota B7200E
I have a mid 80's B-6200 hst, power steering and loader.
while I was checking my oil, I noticed the oil was farther up on the dipstick than it should be. I had recently added hydro fluid because I noticed I was having to push farther down on the hydro pedal to move faster. I drained the engine oil to the correct level. I ran the tractor for a couple of weeks than checked again and the level had risen again.
I looked at my parts manual and saw a oil seal around the hydraulic pump shaft.
Is that the only place where it is possible to mix hydraulic fluid and engine oil? Especially at that rate? I guess it could be from the powersteering somehow but I haven't looked into that yet.
I will fix this myself so taking it to the stealership is not an option. If I can rebuild the engine I can fix this problem.
Thanks in advance,
Jeff
/ Crankcase oil level rising #2
what problem? you got it nailed already and just need the seal/time/ beverage of choice and you'll be back in tractorin bliss........... /forums/images/graemlins/laugh.gif
/ Crankcase oil level rising #3
</font><font color="blue" class="small">( . . .
Thanks in advance,
Jeff )</font>
As strokerduster says, you've got it figured out. The power steering pump could also be a souce. But, the main culprit is likely the hydraulic pump with its greater volume.
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
Kubota M4700 (A60462)
207277 (A52708)
207277 (A52708)
2022 Bautista Welding and Custom 40ft. 10 Ton T/A Gooseneck Flatbed Trailer (A61573)
2022 Bautista...
2022 EZ-GO ELITE...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
