Craftsman Lawn Tractor
/ Craftsman Lawn Tractor #1
MarkV
Super Member
Cedartown, Ga and N. Ga mountains
1998 Kubota B21, 2005 Kubota L39
I should wait to post this until I have all of the information but may be I can get an idea of everyone's general thinking. We are buying a new place and the present owners have a 1 or 2 year old Craftsman lawn tractor they are offering for sale. I have seen the mower but didn't pay a whole lot of attention at the time so I don't have the model number. From what I remember it was 20 hp and I think it had a 48" deck. Are there any general thoughts on the Craftsman line of lawn tractors? Any particular models to stay away from?
Thanks,
MarkV
/ Craftsman Lawn Tractor #2
The 20 hp with the 48 inch deck will probably be the Briggs & Stratton engine. It will have the vtwin and is fully pressurized which is good. Check to see if it is automatic or manual transmission. If you plan on using it for winter snow removal you may want a manual over automatic. If only for mowing the automatic is nice.
These machines have proven to be very reliable and easy to maintain.
PJ
/ Craftsman Lawn Tractor #3
Depends on the year; craftsman (sears) doesn't make their own tractors, they just buy other people's and rebrand them.
This year's crop of tractors are actually rebranded Husqvarnas (the ones with the fender mounted hydro) and I think they're pretty good. They have v-twin kawasaki engines, and husky makes nice machines; I bought the 1542XP version.
Don't know if the older models are also husky or another manufacturer.
/ Craftsman Lawn Tractor #4
IMHO, unless you are getting a real good bargian on it , stay away from it. The craftsman mowers I have seen probably have the poorest deck design on the market. Another downside to craftsman is the star design on the blades. You almost have to purchase blades from sears.
Thanks everyone. You have given me the things to look for next time we get a chance to look at the mower. I'll find out the year, engine brand, and deck/ blade combination. Forgot to mention it but it is the auto tranny and snow is not an issue here.
Thanks again,
MarkV
/ Craftsman Lawn Tractor #6
I've had very good luck with Craftsman lawn tractors. Just bought my second one. I gave away the 10-year old one, it had gotten to where it mowed crooked. The person I gave it to says it was a missing spring in the deck.
I've never had any trouble with the deck on the old one, as far as bearings or anything else.
/ Craftsman Lawn Tractor #7
I have a GT 18 I bought in 1996. It has a 44 inch deck and is a hydro. Until recently it had been very reliable. I'm having problems with keeping main drive belts on it. In another post I received good advice and am in the process of checking, replacing and realigning the pullies. I do think the design with the belts being twisted and wrapped so much is a poor design.
/ Craftsman Lawn Tractor #8
kind of late to this post ,but what the heck! bought a sears 18hp GT back in may 92, in the next 15 months they had to replace the transmission 3 times, finally they said i could pick a new model or get my $$$ back. went to the store and picked the new model comprable to the old one. going into the 11 year with that machine and the only thing i have had to replace other than normal stuff(belts, blades) was a starter motor. i work that thing hard and often. keep it well maintained and there is no sign of rust on the deck. would i buy another? YEP.
/ Craftsman Lawn Tractor #9
I have 18hp kohler and 44" deck works great since 1990-91 on 2nd set of blades still runs great and still out cuts my neighbors deere's..
/ Craftsman Lawn Tractor #10
</font><font color="blue" class="small">( IMHO, unless you are getting a real good bargian on it , stay away from it. The craftsman mowers I have seen probably have the poorest deck design on the market. Another downside to craftsman is the star design on the blades. You almost have to purchase blades from sears. )</font> Quality varies greatly on these machines. The ones with star mount on the blade are likely MTD machines. Poulan, Murray and several others have made them as well. Look 'em over well for quality of engine, steering components, comfort, ease of maintenace, etc... Heck, so many folks dislike Murrays and I currently have 3. 2 are hydros and 1 is gear garden tractor. All perform very well with the exception of the soft quick wearing blades. The 96 18.5hp 48in deck model just lost it's 1st mandrel bearing. It cut 6 acres for 5 yrs before I aquired it and the deck suffered some from the deck sitting for a year while I used it to pull trailers and a spreader. Frequent greasing, cleaning deck over/under and servicing engine go a long way. The newest had dry zerks all over, but don't know if it was an assembler problem where bought or factory. They get checked over and greased regardless. Also wrapped some wiring in conduit and did a bit of rerouting before it cut 6 acres the 1st day. Gear drive is a bit annoying after using hydro too. Highly recommend the hydro if you've got thick and thin areas where you'll be changing speed often. Good luck with whatever you choose... /forums/images/graemlins/laugh.gif
/ Craftsman Lawn Tractor #11
I have a 23 hp craftsman garden tracor with hydro transmission a dump cart a sleeve hitch and an electric lift. a homemade drag , a potato plow , a box blade and harrow. I bought it in 2001 I used to to move gravel all over my yard and level and grade some. It looks durable is comefortable to draive and well made I have had no problems with it. I think you get a lot for your money. I have never cut grass with it I have no grass ! I bought it at the time because I could not afford a desiel tractor , also it was new sears had 0% financing during the sping and they stand behind their warantee if I did not like it I could have returned it. Take care and good luck with your decesion. David
/ Craftsman Lawn Tractor #12
I have a 15 HP 41" or 42" wide deck,bought it new in 1996,and I have mowed a lot of grass.It is getting to the age where I am going to have to spend a little money,but it has been a good mower for the money.
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2025 SDlanch SDLD25 (A64127)
2025 SDlanch...
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
2006 STERLING AT9500 6X4 T/A 14FT DUMP TRUCK (A59914)
2006 STERLING...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
