Craftsman 42" tractor
/ Craftsman 42" tractor #1
mernestm
Cub Cadet 2135
I have a craftsman 42" tractor with a Briggs & Stratton engine. It starts up fine and runs for a while (i/2 hour or so) and then dies like it ran out of gas or spark. Once it cools it runs fine again until it heats up. I changed the fuel filter and air filter and now wonder if it might be the coil. Any suggestions?
Thanks!
Michael
/ Craftsman 42" tractor #2
When it dies you could pull the line loose from the filter and see if you still have gas flow. You could crank it over while checking for spark. It could be the coil - not uncommon. It could be the spark plug. Check your air filter while you're at it. In really weird cases the magnet on your flywheel could have lost some strength giving very weak spark.
/ Craftsman 42" tractor #3
Which engine?
Is the failure time consistent with weather/temperature? There have been a few reports of the vent hole in the filler cap plugging up. This makes the tank 'draw a vacuum' and slows fuel flow starving the engine.
It is a Briggs & Stratton 18.5 HP model 407777-0121-E5
/ Craftsman 42" tractor #5
Make sure your gas cap vent is not plugged. Clean gas cap vent to be sure this is not the problem.
/ Craftsman 42" tractor #6
Could be a bad coil, I had one act like that on a B&S a few years ago, shut down when got hot.
/ Craftsman 42" tractor #7
Craftsman never made a tractor with a 42in deck. They made lawn mowers. Have you replaced the carb? It could be as simple as the main jet not keeping up with the fuel needed for the engine.
/ Craftsman 42" tractor #8
My money is on the coil. It would draw a vacuum on tank quicker than that if its full of fuel and cap stopped up.
/ Craftsman 42" tractor #9
Heat it up till it dies and won’t start. Give it a shot of ether and see if it fires. That’s the simplest way to verify whether it’s fuel or fire.
Genie GS-3232 32ft Electric Scissor Lift (A64553)
Genie GS-3232 32ft...
1995 Ford LT9000 Tri-Axle Dump Truck (A64556)
1995 Ford LT9000...
2022 EZ-GO ELITE...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
2011 Nissan Murano SUV (A64557)
2011 Nissan Murano...
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
