Cracks in Axle Housings
   / Cracks in Axle Housings
Yeah Jag, I know what you mean. Too much information can sometimes be a bad thing when it comes to sanity/w3tcompact/icons/crazy.gif
Scott
   / Cracks in Axle Housings #12
Yes the older housings are the same surface all the way accross. Don't know for sure when the change was made.
No service bulletin out. Have changed more than a few.
when ordering replacement housing they "majically" come in with the machined surface.
   / Cracks in Axle Housings #13
Scott and everyone else, now that you have made me think and go take a look, (now I am ok) Has any one who has a cracked axle housing had a FEL on it. My L2650 ROPS has a flat plate on the bottom (top of axle), and a flat plate on the bottom where the FEL support ties in. It is bolted together with four regular bolts, not U-bolts.... Has this type of setup ever done the no-no to the axle?
   / Cracks in Axle Housings #14
Jag -
Is your setup similar to my L2500 as partially shown in this picture?
I'm following this thread with interest. /w3tcompact/icons/crazy.gif
   / Cracks in Axle Housings #15
Damm it Harv, you have made me climb under the tractor the second time.... Ha, ha it was parked out in front without anything hooked up.... Hate to tell you this but no. My axle housing (1995 model) is square the mounting plates fit down flat on the housing.... Also on the back side, now that I have looked closely, the housing has four machined holes with plastic plugs (about 1/2 inch) already there for mounting some attachment...
Jag,
I'm not sure about the FEL brackets causing cracks - this would be a better question for kubmech. The FEL bracket on mine bolts to a separate hole on the axle housing -not to the ROPS mounting (the setup on the Grand L's is a little different than the L series).
Scott
   / Cracks in Axle Housings #17
jag, don't sweat it, never seen the "no-no" on a 2650 and it's likely I wont. ( unless you lay the tractor on it's side and hook up to the loader lower frame support to pull it back up-right and in the process rip the bolts out of the axle assy. but that"s another story) If you have a "10" series grand L check to see if the axles have the machined surface, if you do you should be ok (so far) but if the surface is not machined, be afraid, be very afraid...............
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2000 FORD F-350 SUPER DUTY (A58214)
2000 FORD F-350...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
S/N: 1240824 (A55853)
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
