Cracks in Axle Housings
   / Cracks in Axle Housings
Yeah Jag, I know what you mean. Too much information can sometimes be a bad thing when it comes to sanity/w3tcompact/icons/crazy.gif
Scott
   / Cracks in Axle Housings #12
Yes the older housings are the same surface all the way accross. Don't know for sure when the change was made.
No service bulletin out. Have changed more than a few.
when ordering replacement housing they "majically" come in with the machined surface.
   / Cracks in Axle Housings #13
Scott and everyone else, now that you have made me think and go take a look, (now I am ok) Has any one who has a cracked axle housing had a FEL on it. My L2650 ROPS has a flat plate on the bottom (top of axle), and a flat plate on the bottom where the FEL support ties in. It is bolted together with four regular bolts, not U-bolts.... Has this type of setup ever done the no-no to the axle?
   / Cracks in Axle Housings #14
Jag -
Is your setup similar to my L2500 as partially shown in this picture?
I'm following this thread with interest. /w3tcompact/icons/crazy.gif
   / Cracks in Axle Housings #15
Damm it Harv, you have made me climb under the tractor the second time.... Ha, ha it was parked out in front without anything hooked up.... Hate to tell you this but no. My axle housing (1995 model) is square the mounting plates fit down flat on the housing.... Also on the back side, now that I have looked closely, the housing has four machined holes with plastic plugs (about 1/2 inch) already there for mounting some attachment...
Jag,
I'm not sure about the FEL brackets causing cracks - this would be a better question for kubmech. The FEL bracket on mine bolts to a separate hole on the axle housing -not to the ROPS mounting (the setup on the Grand L's is a little different than the L series).
Scott
   / Cracks in Axle Housings #17
jag, don't sweat it, never seen the "no-no" on a 2650 and it's likely I wont. ( unless you lay the tractor on it's side and hook up to the loader lower frame support to pull it back up-right and in the process rip the bolts out of the axle assy. but that"s another story) If you have a "10" series grand L check to see if the axles have the machined surface, if you do you should be ok (so far) but if the surface is not machined, be afraid, be very afraid...............
CATERPILLAR 299D3 SKID STEER (A52709)
CATERPILLAR 299D3...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
2019 International Bucket Truck (A55973)
2019 International...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
TANK MANIFOLD (A58214)
