cracked steering unit
/ cracked steering unit #1
Officedoor1
mahindra emax 24
I have a mahindra 2014 emax. First the hose blew on the left side for steering. I replaced the hose then the steering unit cracked. Any ideas on what is wrong.
/ cracked steering unit #2
Welcome to TBN
1st thing I'd recommend is to check steering system psi.
Thank you that i will do and get back to you thanks
/ cracked steering unit #4
Did you have to remove more than one hose to replace the blown hose? If yes triple check to make sure that you have all of the hoses connected correctly.
2021 PETERBILT PB337DUMP TRUCK (A63276)
2021 PETERBILT...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2017 TROXELL 150...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
New Holland 216 Rake (A63688)
New Holland 216...
2016 Ford F650 Ext Cab Flatbed Truck (A62613)
2016 Ford F650 Ext...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
