cracked front axle ym2000
/ cracked front axle ym2000 #1
tmil50
Yanmar YM2000
I cracked my front axle and have found a new one but I can't get the wheel spindles off. Has anyone done this before? I'm not sure how I broke it but it must have been awhile ago because of the rusk in the crack. My land was pretty rough when I first got it and have done alot of grading since then.
/ cracked front axle ym2000 #2
You should remove nut #38, then remove steering arms #20 and #21. Then your spindle should knock out with the bottom bearing on it. At least that is what I see from the parts drawing. Yanmar Tractor Parts: FRONT_AXLE_2WD
/ cracked front axle ym2000 #3
I have had mine off a couple of times. If the woodruff key (33) gets out of alignment at all in the slots, it can make it very hard to get off. Good luck.
2009 Ford LCF Box Truck (A66285)
2009 Ford LCF Box...
207923 (A63290)
207923 (A63290)
2016 CATERPILLAR 926M WHEEL LOADER (A65053)
2016 CATERPILLAR...
2020 Chevrolet Tahoe SUV (A64557)
2020 Chevrolet...
Kubota L2501D 4x4 Utility Tractor with Land Pride 72in Brush Cutter (A64553)
Kubota L2501D 4x4...
18' Pipe Gate (A66408)
