Crab Grass Preventers
/ Crab Grass Preventers #1
JDGREEN4ME
Southeast PA
John Deere 2520, John Deere X534, GT 225, GT 275
Do any of those preventers (Scott's, etc.) help control crab grass? Do you mow and/or dethatch prior to application?
/ Crab Grass Preventers #3
You should do all your dethatching and core aerating before spreading the crabgrass preventatives. The active ingrediate coats the ground and prevents seed germination. Dethatching and core aerating after this chemical coating occurs decreases the effectiveness as it opens up soil that hasn't been coated.
/ Crab Grass Preventers #4
I think I have had good luck over the years broadcasting crabgrass preventer, but the timing is critical up to a point. The directions vary from "apply the first period of three warm days over 70°" to "apply after the forth mowing". I find that I get little to no crabgrass where I apply it and crabgrass where I do not apply it. That is over about half of my 8 acres. Certain areas there doesn't seem to be a crabgrass problem at all.
I only have applied the pre-emergent variety, and not the liquid.
/ Crab Grass Preventers #5
Around here the Mother Nature timetable is to apply the crabgrass pre-emergents when the Forsythia bloom.
/ Crab Grass Preventers #6
DocHeb
I've heard that too, as well as when the lilacs bloom. I've had a lilac bush in the yard for 25 years and it has never bloomed yet.
Kids bought us a new one last year and we'll see if it will bloom this year /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
/ Crab Grass Preventers #7
yup, heard that since I worked at Agway. I go by Forsythia but that is me.
I rake or “broom” the grass, aerate or plug and then put the goo on!
/ Crab Grass Preventers #8
Anything work on Bermuda?
Most of the ones I've seen said for use on Augustine only.
anthony
/ Crab Grass Preventers #9
There is a difference in active ingredients and when to apply for the best control. Most of the chemicals will not have much post emerge control. The two most common are Pendimethalin and dimmension. The dimmension has good control even if the weed grasses are into the two leaf stage. In northern Illinios and Iowa we can put dimmension products down until the first part of may. The chemicals typically last 8 weeks and as others have said you do not want to disturb the soil after you treat. Grannual programs work well and spray works well too.
Schulte Batwing Rotary Brush Cutter Tractor Attachment (A61572)
Schulte Batwing...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
Skid Steer Logging Winch (A64047)
Skid Steer Logging...
2014 FREIGHTLINER CASCADIA (A63569)
2014 FREIGHTLINER...
