Cover for steering column
/ Cover for steering column #1
Sparker79764
TD 5059
How to remove cover over steering column
/ Cover for steering column #2
Not much for details are you? Assuming you're working on a New Holland TD 5050? There is no TD 5059.
The earlier TD tractors had a full metal shell around the steering column that didn't come apart from the outside. It was a series of metal panels all bolted together on the inside with 1/4" bolts, nuts, and washers. Later ones had a panel or two that could be removed from the outside. You can scan through the parts lists and see if anything looks like it matches your tractor.
8x5 Cattle Panel Gate (A64047)
8x5 Cattle Panel...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2001 Eager Beaver 50 Ton Hydraulic Detach Lowboy Trailer (A64047)
2001 Eager Beaver...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
Hydraulic Fire Plow Attachment (A61572)
Hydraulic Fire...
John Deere 4044R (A62177)
John Deere 4044R...
