Cover backhoe when snowblowing?
/ Cover backhoe when snowblowing? #1
Ken P
North Granby, CT
Kubota B2410
Folks - For those of you who leave your backhoe on when you snowblow, do you cover it in any way? Obviously this is my first tractor - a Kubota B2410 - and I was planning to leave the BH on through the winter during snow removal operations. But, I was wondering if it would prevent water/ice working it's way into bad places if I covered the BH with a tarp; it appears as though I could nicely bungee a tarp around the upright arm.
Thanks for helping a newbie -
Ken
(awaiting the first big storm supposedly coming this weekend ..)
/ Cover backhoe when snowblowing? #2
I bet you could get an auto body shop to sew you a custom cover for it. Might cost you a hundred or so.
/ Cover backhoe when snowblowing? #4
There really is no need to, but knock yourself out if it makes you happy. I'd be more afraid of whacking into something like a car, house, mailbox, etc with the hoe on the back.
I'd be surprised if you could get a custom cover for under $250-300 bucks, unless it looked like a 'tater sack. But our prices may be sky high!
/ Cover backhoe when snowblowing? #5
The only issue I see is water getting into all the pins at the joints. I think if you keep it well greased it won't be a problem. My backhoe stays on most of the time and the tractor is stored outside in the rain and snow. No problems so far.
/ Cover backhoe when snowblowing? #6
I left mine on the first winter....as stated, the chance of running into something is a bit elevated with the hoe in place. I found myself swinging it off to the side to shorten things up....but that just made things wider in one direction. That almost got me in trouble a couple of times. I have found that once the ground freezes up, I drop it off cause digging would be a little tough anyway.....and the practice of taking it off/on is a good thing.
Thanks folks. I guess I'll grease the joints well, try a bungeed tarp, but not worry about it too much. There isn't much to hit near my driveway (I know, famous last words).
Ken
/ Cover backhoe when snowblowing? #9
I leave mine on all the time.
I do go over the tractor with a snowbrush after blowing, and park it in the sun as soon as I can to melt it off. When parked, it sits under a lean-to roof. No problems with backhoe so far, and it does make a great weight for the rear.
/ Cover backhoe when snowblowing? #10
I take mine off, because that's where I mount the snow blower...but leave my FEL on so that I can use it to move snow around, and occasionally run into things while I'm backing up and not paying attention. :-/
/ Cover backhoe when snowblowing? #11
My hoe must also come off to mount my blower.
I have found that if I cover stuff up with tarps and such, that it makes a great hiding spot for critters that chew seats and hoses. It also tends to cause condensation under there.
I'd like to store it in a covered shed with lots of ventilation but NOT wrapped up tight
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
24in pin on excavator tooth bucket (A61307)
24in pin on...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
2007 International 8600 Parts Truck (A63689)
2007 International...
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
2016 Nissan Altima Sedan (A61574)
2016 Nissan Altima...
