Couple of Zerk questions
   / Couple of Zerk questions #1
drjay9051
Morriston, Fl. 40 miles west of Ocala. More cows
Kioti DK 40 HST
OK. So my adventure continues. I spent 8 houirs yesterday working on the tractor. Finished fluids, removed hood and really cleaned the thing, touch up paint etc, Got to the grease fittings and had some issues.
The manual for my CK25 shows zerks for the top link I saw none. The manual does not show any zerk for the leveling link but there was one hidden beneath a rubber plug. Manual also shows a zerk for the brake. I traced the brake from the pedal back to the rear axle and saw no zerk. Any thoughts?
On the front there are both right and left side zerks for the power steering : no problem on the right but the left will not accept grease. How do I remove and replace zerk? Doesnt seem to screw off and I really am stuck on this issue?
BTW: Learned a couple of new things. There is a sight glass on the front axle to check gear oil level. Dont know why but manual says to remove when changing out oil. So I go to put it back in and get heavy handed: shear off the bolt! Thats why there is an O ring so you don't overtighten. Go to NAPA and get a 1" pipe plug. Temporary fix, sight glass will be in Tuesday. $15.00 Why the manual calls for removal of sight glass plug is beyond me.
Lastly: Not mentioned in manual but I realized the gray side panels below the hood are easily removed to allow access. Makes oil filter removal easier. I found this out when I needed to access alternator bolts to tighten up belt. This also allowed me to paint them as they were a bit beat up.
Overall a long hot day in Florida but a great learning experience.
Today I tackle the FEL: clean, paint and grease
Happy holiday, everyone
J
   / Couple of Zerk questions #2
There should be 2 zerks on the 3PH leveling arm. One near the top and one by the crank handle. There should also be one right behind the leveling arm (right side when facing the rear) on the 3PH arm mechanism (I think that is what it lubricates). It's there, just not easy to see.
Usually you can get grease in the power steering by lifting the front end off the ground with the loader, and turning the wheel some while trying to fill. Don't forget to grease the cylinders on the front end too.
I lifted the front axle with the loader. Worked the steering back and forth. Still the fitting wont take grease. I had a similar problem with a FEL zerk but was able to remove pin and clean after that no problem. I dont have that option here. Anmy thoughts??
   / Couple of Zerk questions #4
You might want to try a needle coupler for the tip of your grease gun as opposed to using those darn external coupler. I use a needle tip exclusively as opposed to externals. A couple of times, I had to either remove and replace with new or wash out a used zerk after removing and then blowing out the zerk with compressed air.
rimshot
   / Couple of Zerk questions #5
There is one for the brake bell crank if I remember correctly, it may take some searching. Also one of those under there somewhere I had to change to a 45 degree angled one, couldn't get on the one from factory.
   / Couple of Zerk questions #6
This is what I use when needed......Alemite 339841 Zerk-Mate Grease Fitting / Joint Cleaner, Grease guns, Cordless grease guns, Battery powered grease guns, Grease pumps, Liquid Filled Pressure gauges, Hydraulic pressure gauges, Paintball gauges, Custom pressure gauges, Flashlight, Too......
If you google "Zerk fitting cleaner" there is less expensive types out there......
works great with light oil/wd40/kerosene/hydraulic oil.....just about any kind of light oil.....just open it up, put in oil,back together, tap with light hammer and done.....well most of the time.....:thumbsup:
2010 Toro Workman MD Utility Cart (A55973)
2010 Toro Workman...
Voltage Converter, Single Phase, 240 Volt Input, 120 Volt Output (A59076)
Voltage Converter...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56435)
2017 Yale GLC050VX...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A58017)
2019 PETERBILT 579...
