Couple of simple Case 530 questions
   / Couple of simple Case 530 questions #1
bmicad
Case 530
What is (or where can I find) the proper tire pressures for my '64 Case 530 loader backhoe? Also, what is the shift-lever on the right hand side between the brake pedals & the steering wheel? Is it a high-lo range or some kind of torque converter control? Thanks in advance!
   / Couple of simple Case 530 questions #2
Lever is probably high/low range. 4 speed manual with forward/reverse lever on the left? Gives 8 speeds for and aft.
Rear tires usually about 30, fronts maybe 35. Tires have some tiny print giving the mas inflation pressure.
   / Couple of simple Case 530 questions #3
Follow this link, and it should give you the info, on about anything for your 530. Look in the menu to the left, where it says manuals. Printable manuals in PDF, if you have Adobe Reader. It's a free download, if not, to be able to open the folders.
Hope this helps..!!
Case 530CK - Tractor Specs
2013 Ford F-150 (A55973)
2013 Ford F-150...
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
2021 Ford F-250 (A55973)
2021 Ford F-250...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
