Couple of simple Case 530 questions
   / Couple of simple Case 530 questions #1
bmicad
Case 530
What is (or where can I find) the proper tire pressures for my '64 Case 530 loader backhoe? Also, what is the shift-lever on the right hand side between the brake pedals & the steering wheel? Is it a high-lo range or some kind of torque converter control? Thanks in advance!
   / Couple of simple Case 530 questions #2
Lever is probably high/low range. 4 speed manual with forward/reverse lever on the left? Gives 8 speeds for and aft.
Rear tires usually about 30, fronts maybe 35. Tires have some tiny print giving the mas inflation pressure.
   / Couple of simple Case 530 questions #3
Follow this link, and it should give you the info, on about anything for your 530. Look in the menu to the left, where it says manuals. Printable manuals in PDF, if you have Adobe Reader. It's a free download, if not, to be able to open the folders.
Hope this helps..!!
Case 530CK - Tractor Specs
UNUSED CFG Industrial MY50R Mini Excavator (A47384)
UNUSED CFG...
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52128)
2024 Ford F-350...
New Holland 1431 Discbine (A50515)
New Holland 1431...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
Toro Mower (A50324)
Toro Mower (A50324)
