Couple more MF 135 Questions
   / Couple more MF 135 Questions #11
G'day scott1-------9.
O.k. The little knurled head adjuster Withthe engine running and the oil hot set the draft lever in the up position and the Position lever in the Transport position then using your fingers move the control valve and listen and watch the lift arms ,they should go down a bit when you move the control valve ,if they do turn the knurled adjuster IN that is screw it into the control arm about one turn should be enough, If this does not work The lift cover will have to be removed ,Let me know and I will talk you through this part.
Regards.
Hutch.
P.S. HUTCH !!
The position lever is still not controlling anything. I tried to take the lift cover off unsuccessfully. I undid everything and got it up about an inch but didn't know what to disconnect to get the rig free. Then as I put it back down the retention springs had come out and I believe the ram cylinder came out as well. I was going to take it to the dealer today but if I can figure out how bot get the lift cover off that would have me $200-300 right from the start.
Caterpillar 262C Compact Wheel Loader Skid Steer (A59228)
Caterpillar 262C...
John Deere 2310 Soil Finisher (A59814)
John Deere 2310...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
2017 VOLVO VNL TANDEM AXLE DAY CAB (A59575)
2017 VOLVO VNL...
2005 MACK CV713 TRI AXLE 16FT DUMP TRUCK (A59575)
2005 MACK CV713...
Ford N Series Tractor (A59814)
Ford N Series...
