Couple issues with CK 3510 se HST
   / Couple issues with CK 3510 se HST #1
MYOLFarm
none yet
Just noticed 2 coolant leaks, one right at the top radiator neck/hose area and one on bottom of motor where a rubber line connects to a hard line. Both have hose clamps and seem to be tight, tried tightning a little with no difference, anyone seen this? Also when going up my drive way I run in second gear, when putting a load on tractor it will pop out of gear into neutral, not every time but frequently, any thoughts on this ? It is about a1 1/2 years old with 100 hrs, what does the warranty cover?
   / Couple issues with CK 3510 se HST #2
You'll have to contact your dealer or check the Kioti website to learn what the warranty covers. Given the age of your tractor all your issues should probably be covered.
   / Couple issues with CK 3510 se HST #3
I agree check with your dealer, those items should be covered.
   / Couple issues with CK 3510 se HST #4
Is this where one of your leaks is? Mine just got picked up today for the coolant leak, I tried tightening the clamp as well as replacing it.
   / Couple issues with CK 3510 se HST #5
Not sure why the image didn't attach, lets try that again.
KUBOTA M955 DUAL SPEED TRACTOR (A57192)
KUBOTA M955 DUAL...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
2021 PJ 16 T/A DUMP TRAILER (A55745)
2021 PJ 16 T/A...
2020 CHEVROLET SILVERADO 3500 HD FLATBED TRUCK (A57192)
2020 CHEVROLET...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
CATERPILLAR D6R XL HI-TRACK CRAWLER DOZER (A52707)
CATERPILLAR D6R XL...
